polish special characters (extended ASCII)
I'm devolpping a soft for a customer that have factories in many countries in Europ (including Poland) so I have to make it multi-lingual.
I 'm using a text file for each language, the issue is that LabVIEW 7.1.1 seems not to be able to display some strange polish letters such as : ł ę ń ć ś ż...
The result I get in LabVIEW's front panel depends on the encoding type of the text file (ANSI, UNICODE, UNICODE Big Endian, UTF8...).
ANSI encoding defenitly doesn't support ISO/unicode characters, but when I open the Unicode encoded text file with notepad the display is correct while LabVIEW display "?" or "" instead of above mentioned characters.
I went through the web to grab some informations and found that these polish letters are supported as ISO/unicode characters (eg : hexa code for "ę" is "0x0119"
Can LabVIEW be configured to support ISO/unicode characters ?
My PC is running WinXP+SP2, LabVIEW 7.1.1
Thanks in advance for your help
TiTou
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(5,382 Views)
I don't think the built in control can help you, but there was a recent thread about using the Windows "rich textbox" ActiveX control to do stuff that a LV text control doesn't support. Perhaps that would be a solution for you as well?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,371 Views)
See the attached very simple example. The control can display the characters, but it might be a mess getting them into the display...
Mike...
Message Edited by mikeporter on 09-06-2005 11:21 PM
LabVIEW Champion
(5,371 Views)
