polymorphic subVI in DB Tools Get Properties.vi
I installed LabVIEW 6.1 with the enterprise software on a WIN2000 (5.00.2195 Service Pack 2) computer (COMPAQ Evo N600c). When I try to use any of the DB access VIs that have polymormic inputs I get the following message " PolyVi 'Name.vi' polymorphic subVI is broken. I have installed the same configuration on the same model Laptop and same OS and it worked fine. ?????
(2,771 Views)
It sounds like you have to reinstall. Before you do that, try a mass compile on the directory where those VIs are installed (the entire NI directory if you have to.) There was probably a problem during installation that caused this problem. I have seen similar, though not with these VIs, and a reinstall fixed the problem.
Also, try contacting NI support on this one. It doesn't sound like something that should be happening. If you don't get a quick response from this forum, you may be able to get a faster answer going through support.
(2,770 Views)
