polymorphic write key
This is probably something simple, but I just couldn't figure it out:(
Write Key in config file vi is suppose to be polymorphic, however, I am trying to write a double precision number, but LV keeps complain the different data type, the sink is boolean, the source is double. Do I need to do something special to enable polymorphic?
I am using LV8
(3,280 Views)
Works fine here. Can you attach a simple example VI that shows the problem?
(3,275 Views)
Perhaps you dropped the Boolean instance of the poly VI on your diagram instead of the poly VI itself?  Try dropping a new Write Key.vi from the palette and wiring to it.
-D
(3,265 Views)
Please look at the attached vi. I think it is because the number is not pure DBL, when I looked its properties, it has some kind of unit(?) there. I think I will change it to enum.
(3,259 Views)
Yes, assigning units to the control will change its datatype, and thus make it an invalid input to the Write Key poly VI.  Another problem is that the units you have assigned are not valid (notice the '?' in the unit label).  If you still want to use a DBL, the best thing to do would be to remove the units from the control by right-clicking, choosing Visible Items > Unit Label, then removing the text from the unit label.
-D
(3,253 Views)
