polynomial question?
What sort of vi to use to constructe the following polynomial equation
y=Ax3+Bx2+Cx+D
I have problem with my English math translation
Thank you very much for your help
Gérard
Gérard Férini
Switzerland
(2,913 Views)
While it is not entirely clear what you mean by "construct", simplest would be to use the "1D Polynomial Evaluation.vi". It will do it for an entire array of x-values at once. (See attached example image).
(2,913 Views)
Or you can do it the hard way:
- tbob
Inventor of the WORM Global
(2,913 Views)
Use the "1D Polynomial Evaluation.vi". Find this in
Functions->Analyze->Mathematics->Array Operations.
TJ Whitaker
"G_F" wrote in message
news:4135dd2b$1@epflnews.epfl.ch...
> y=Ax3+Bx2+Cx+D
> Gérard
> Gérard Férini
> Switzerland
(2,913 Views)
