pop up messages
How do I pop up messge with Close button in the small window? When I push Close button, the windown will close, similar as the error message from windown operating system.
If I change the VI properties using SubVi, it pop up a labview window. I just want a small message window.
(2,696 Views)
The Time&Dialog function palette has One Button Dialogs and Two Button Dialogs. For either dialog, you specify the message. In the One Button Dialog, the user clicks OK to continue. In the Two Button Dialog, you can specify the names of the buttons (Yes/No, Ok/Cancel, etc.) and see which button the user clicked.
To get to the dialogs, right-click on an open spot on your diagram, then goto the Time&Dialog palette, then look for One Button or Two Button dialogs.
(2,696 Views)
