popup
Hello to all,
I wanted to ask you a question.
I made a program for monitoring the temperature. Exceeded certain limits, the program returns of alarm messages. These messages contain references to legislation. Is there a way to click on a word (of the message) and bring up the reference?
Message 1 of 18
(4,721 Views)
"References to legislation"????
Post a screenshot so we know what you are talking about.
Message 2 of 18
(4,717 Views)
Do you want to display html type text?
Message 3 of 18
(4,711 Views)
Is not important.
The message contains a sentence which refers to the law. I would like to be able to click on a word in the sentence (such as a button) and bring up the piece of law to which I refer.
code is complicated (and, because of my lack of practicality with labview, too messy), so needless to attach it.
In summary, it, as a result of some tests nested in "Case Structures", complete with a table of messages.
Message 4 of 18
(4,708 Views)
To 1984:
No. I want a kind of popup ...
Message 5 of 18
(4,706 Views)
It sounds like you want a hyperlink of some kind.  When the user clicks on some word in a message to do some action.  LabVIEW doesn't have this support nativly but you can reproduce the functionality using other techniques.
Here is a quick example of what you can do.  I made a VI with some text in it and I colored a word blue so you'd know you should click it.  On top of this word I put a transparent button that captures the mouse down event and prompts if you click it.  I did the same with a label because I didn't know what you meant by "message".
Message 6 of 18
(4,680 Views)
Can I ask you to save it in an older version? (Eg 9 or 11)
thanks
Message 7 of 18
(4,669 Views)
Thank you very much.
I ask you one more thing: how do I assign the "button" to the words?
Message 9 of 18
(4,661 Views)
.... and if the string was a constant that only appears with certain conditions?
Let me explain:
I have a table that you fill in automatically depending on conditions. The message with which he fills the table is a string (constant) at Block Diagram.
How do I set the buttons at Block Diagram?
Message 10 of 18
(4,654 Views)
