port setting conflict
hi there. can someone help me with my issue.
i am no experience with communicating with hardware. i am trying to set  4 oven to a certain temperature.
this is a new system so it is not currently working yet.
can someone help me with troubleshooting this.
i have an image of the current problem.
thanks
Message Edited by krispiekream on 08-13-2008 12:12 PM
Krispiekream
(2,637 Views)
Seems like your port is in use by another application...you have another program open to control your oven? You are sure you have used the right COM-Port? No Serial Mouse connected which is in use by Windows? What about your COM 1 and COM 2? There's no error-sign...you already tried connecting your device to this port?
*edit* And: Look at your baud-rate...it's not a valid value for a RS232-communication...
Greetings
Christian
Message Edited by cschneider on 08-13-2008 10:20 PM
THINK G!! 😉
Using LabView 2010 and 2011 on Mac and Win
Programming in Microsoft Visual C++ (Win), XCode (Mac)
(2,620 Views)
thanks for your help.
i uninstalled the current visa software and reisntall in the older version and that seems to solved the problem.
everything is working now.
THANK YOU SO MUCH!!!
Krispiekream
(2,609 Views)
