porting a labview application from windows to linux
I need to compile a labview application that has been created for windows under linux. It depends on calls to functions NBFifoCreate and NBFifoWrite. These are part of the nbfifo.dll library under windows. Could anyone point me in the right direction how to replace this dependency?
Also I am trialing LabView Professional Linux. As I am reading along I gather that I might need LabView RT Module. Is that correct and does it come included with the Professional version.
Thank you in advance.
(3,069 Views)
Hello Damien1979,
It sounds like you have an application developed under the Windows OS which used features of the LabVIEW Real-time Module.  Now, however, you are trying to open the same VI or Project under Linux.  Is that correct?
What distribution of Linux are you using?
Which version of LabVIEW are you using?
The LabVIEW development system is supported under Linux, however, not all modules and toolkits are available for installation.
I believe the NBFIFO.dll related files are associated with the LabVIEW Real-time module, but I haven not confirmed that yet.
George T.
Senior Applications Engineer
National Instruments UK and Ireland
(3,035 Views)
