position object panel
How to fix the position from object
(2,446 Views)
I am not sure what you mean, but to fix a front panel object so it is not moved accidentally, you select it, then click on "reorder...lock" (rightmost button on the tool bar).
(LabVIEW 6 and later only, I believe).
(2,446 Views)
