post message
When I'm done with a Bluetooth Device in LabVIEW can I unpair it from the host machine using LabVIEW?
(2,789 Views)
Unless you are able to write a command to your device, which will unpair the device prior to closing the connection from LabVIEW, I don't believe there is a specific command to perform such an operation in LabVIEW.  If this is a standard Bluetooth operation, this will make a great product suggestion to NI:
 http://sine.ni.com/apps/utf8/nicc.call_me
Best Regards,
AG
(2,743 Views)
