postgresql
i have installed  LABSQL i can connect to the local .mdb base exemple using ODBC.
Now, i would like to establish a connection to a postgre 8.4.5 database without using ODBC
i have posgreSQL driver 8.4.200
i tried using this string and others variations without success
Provider=MSDASQL.1;
Extended Properties="DRIVER={PostgreSQL ANSI};
SERVER=aaaa.bbb.bbb.fr;
UID=name;        /////   name = schema
PWD=pass;
READONLY=0;
DATABASE=DIDB"
how can i add the 5432 port ? PORT=5432 ?
Regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(5,795 Views)
Is there a reason you don't want to use ODBC? How else are you planning to talk to the database? OLE DB?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(5,773 Views)
I tried to use odbc to acces a postgre database
opening connexion to database seems to be OK but i encounter an error wanting to open a table.
Someone has an idea ?
 Regards
Tinnitus
(5,737 Views)
There's a postgresql odbc driver that I've used with great success
(5,562 Views)
The function that is throwing the error looks like it wants to execute a query called "test", but you are trying to open a table.  ??
(5,547 Views)
Hi tinnitus,
Are you using the NI database toolkit?
Because the NI database toolkit works with PostGreSQL, if so, you can PM me and I'll send you an example program
Rodéric L
(5,521 Views)
Why are you responding to a year old thread?
(5,508 Views)
