potentiometers
Good day!
Our professor instructed us to simulate a robotic hand using LabView and Solidworks. He said we should construct real-time controller using a potentiometer. Being new to these softwares, I really don't know how to start. I have read several articles for beginners and somehow got a little knowledge about LabView, but reading the articles that discusses programs using potentiometers confuses me. These are what I cannot understand.
Is there a potentiometer component available in LabView or do I need to have a real potentiometer? If so, how will I integrate this with LabView?
Is the output a varying voltages? If not, how will I make the output one?
Thank you very much.
(3,295 Views)
  • Is there a potentiometer component available in LabView?(no)
  •  do I need to have a real potentiometer?(ask your proffessor)
  • how will I integrate this with LabView?( by hardware or by software simulation)
  • Is the output a varying voltages?(yes)
  • how will I make the output one?(by hardware using AI of Daq reading the variying voltages or by software simulation using a voltage slider on the front panel)
(3,272 Views)
Accepted by topic author sjay
If this is just a simulated robotic hand (no external hardware involved), you can of course create a software simulated potentiometer using a front panel knob and some code behind it.
I recommend to start with this. The harder part will be the hand simulation anyway. 😄
(3,232 Views)
