power spectrum averaging
I am performing a power spectrum and averaging over a number of spectrums.  In addition to saving the average power values for the spectrum, I would like to save standard deviation, max, min.  Is there a way to do this?  It seems that in the Power Spectrum dialog box there is only the option to turn on averaging, but not to save this other data.
(2,846 Views)
Hoe do you want to save the data (format)?
If you want you can save the value as txt numeric data in spredsheet file.
Or do you have any other idea
Regards
(2,829 Views)
