power spectrum using yule walker method
i am currently working on an algorithm and i need to add a power spectrum using yule walker method or modified covariance method or any other power spectrum estimation method except music and fft (periodogram) that i already did. can anybody help me?or does anybody have any other vi that calculates the power spectrum?
(3,430 Views)
Hi hampis,
I posed a similar response on the yule walker forum.
If you're running LabVIEW 8.0 or 8.2 you can use the MathScript node to execute the aryule() function, which uses the Yule-Walker method to estimate autoregressive (AR) model parameters.
Here is more information on this command:
aryule (MathScript Function)
Michael K. | Applications Engineer | National Instruments
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
(3,415 Views)
It didn't appear to hyperlink.
One more time!
Michael K.
(3,413 Views)
thanks Michael
ill try that
(3,364 Views)
