ppm to bmp conversion
I'm looking for a ppm to bmp converter.
Is there any integrated function in LabVIEW?
Do you know a basic .exe I could use if not?
Thank you in advance.
Bim
(3,162 Views)
Hi bim,
the ppm format is rather easy to decode.
So you can:
- write your own decoder and use the LV "Save BMP" function
- use the netpbm package (use Google for a search) to convert the ppm to bmp (or PNG for better compression)...
Message Edited by GerdW on 09-28-2009 11:49 AM
(3,158 Views)
