pre trigger for USB-4432
Hello, my name is Dimas aryo, student of Institut Technology of Bandung..I'm still doing my final project.. my hardware is USB-4432..I have succeeded to build Triggering program, and can start taking data at certain level ( 0.2 Volt )..but i'm still confuse how to see the data at certain seconds before start  taking data ( Pre-trigger ). I'm using DAQmx for the driver..and LabVIEW8.5..
Your help will be aprreciated.. better that you can attached it..
Thank you very much guys... GBU All...
(2,984 Views)
Hello Dimas-
     I think what you are trying to do is use a reference trigger.  From LabVIEW, select Help»Find Examples.  Once that opens, take a look at Hardware Input and Output»DAQmx»Analog Measurements»Voltage»Acq&Graph Voltage-Int Clk- Dig Ref.vi.  The digital reference trigger will wait until the number of pre-trigger samples has been gathered before it registers a trigger on the specified line.  At that point, it works like a circular buffer, continuously throwing away the oldest sample as the newest sample arrives.
     I hope this helps.  Best of luck with your application!
Gary P.
(2,970 Views)
Hello Mr. Gary,I have tried using Reference analog edge and Reference digital edge for triggering, but the hardware of USB 4432  cannot respons anything for acquiring the data... i have tried with property node of trigger, and the respons still the same.. Is it possible that we can build pretriggering program manually without using DAQmx ? .....
Thanks for your helping and attention... Gud Luck sir...
(2,961 Views)
