precision of number in chart
hello,
I've made a Vi who can trace the characteristic curve. All is ok but sometimes I see a stable period in the curve. But in fact the spots are not stable but the difference between them is too small. I've got this values for exemple : 0,00634436 and 0,00634259. In the cart the value is 0,0063. I need to increase the senssibility of the chart but I couldn't succes.
How can I do this ?
Thanks a lot for your help !
Emmanuel
(2,704 Views)
Hi Emmanuel,
you can change the settings for the chart, but why do you need such precision values in your chart?
Mike
(2,700 Views)
I try to change the setting but nothing change in the chart.
I need this precision because I cannot have a big current and I need to measure low resistance. So my voltage doesn't change a lot. When I export my curve in excel, it's a line but not in Labview.
When I have 7 significant numbers for the Y axis, nothing change.
I don't know what to do.
Thanks for your help.
Emmanuel
(2,687 Views)
Hi Emmanuel,
if you select a smaller range, then the numbers will be better. In which range do you need this precision? From 0 to 10 won´t be possible. Smiley Wink
Mike
Message Edited by MikeS81 on 08-04-2008 01:51 PM
(2,682 Views)
Hi Mike,
I'm in auto range !
But then I'm in my table and in my chart the values are in V.  But my Keithley measure values in mV or µA ...
Thanks !
(2,678 Views)
