‎08-16-2007 09:39 AM
‎08-16-2007 10:45 AM
‎08-16-2007 10:53 AM
‎08-16-2007 11:04 AM
‎08-16-2007 01:41 PM
Is there a timeline for fixing this issue?
Can I get on a notification list for when it is patched?
‎08-16-2007 02:04 PM
‎11-25-2008 05:06 PM
I think I am seeing the same issue, but since I am developing on XP and deploying onto Vista, I assumed that was the problem. My issue is with a table control; the custom RTM does not work when saved as an external file. It does work in the development environ and EXE on the development machine (XP in my case). After reading this I tried saving with the control. Now my app works on XP and when installed on a Vista machine.
I sent it by email to NI as a tech support issue, but if they regard it as an installation/EXE problem rather than a change in OS problem, my comment is redundant.
Hope this helps others.
Derek
‎06-07-2012 12:38 PM
I realize this is a thread resurrection, here is my justification:
So, I seem to have this issue as well. The posted work-around of making then undoing a small change in the RTM editor and choose to save the menu with the control instead of a file still works.
My reasons for resurrecting this thread is that I want to know if CAR 3T2E57V2 was ever closed at some point and this is a new issue that should be given a new CAR, OR if this is the same issue and it was just never resolved?
Q
‎06-08-2012 01:54 PM
Hi Q,
This CAR is still open and has not yet been resolved. Is the workaround provided sufficient for you?
‎06-08-2012 02:21 PM
yes it is, once i found it. must be a hard nut to crack 😉
