press button in while loop and make 1 iteration
Hi, and happy new year:
I'm trying this: when I press the button it makes a determinate action, in this case, to catch the number (in this moment) that is runnig in another while loop. This button is into a second while loop and this is "waiting". When I press the button will catch the number and return to initial position. In this example I catch 2 numbers, one when I press ON and the other when the button return to OFF. How I catch only one of them?.
Vicen
WinXP / LV7.1
(3,842 Views)
Right click on the catch button, in drop down menu, go to mechanical action
Make the catch Button's Mechanical action>> Latch when released
This will solve your twice updation problem
Look at attached vi
Dev
Message Edited by devchander on 01-04-2007 04:34 AM
(3,833 Views)
Hi vicens,
just change the mechanical action of (all!) your buttons to 'latch when released' and everything is fine 🙂
(3,827 Views)
Thanks... it's so easy!!! sometimes the solution is in front your eyes and you don't see!!!
(3,820 Views)
