pressure & temperature monitoring with cRIO-9082
Hello. I need to quickly write a simple VI that acquires analog input data from a cRIO-9082 using NI-9205 and NI-9213 modules to acquire pressure and temperature measurements. I don't need to log data, only monitor the sensors. If anyone already has such a program and is willing to share, it would be greatly appreciated. Regards, Bill
(2,930 Views)
Is it an RT controller or does it have Windows on it?
There should be examples which do exactly that, make sure to look through the example finder!
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
(2,913 Views)
It is an RT controller. I wrote a quick program to transfer the data using ftp from the target to the host. I just need a quick program that acquires data from Ni-9205 and Ni-9213 on the target. I looked at the examples first but did not see aanything in lv2012. I'll look again but could you recommend something?
(2,910 Views)
On the main page of LabVIEW 2012 select create project, CompactRio (from the left pane) and select which sample you want to use (there are three, I would use the RIO Scan Interface initially). These are pre-built projects which have a lot of built in functionality, so they should do more than you need.
(2,907 Views)
