pressure readings
I have two pressure transducers wired to a cDAQ9172 through a 9239 module.  I haven't been able to reset the readings from voltage to pressure.  Where can i find the scale reset?
(3,197 Views)
Have you specified Pressure with the DAQ Assistant or the DAQmx Create Channel?
(3,174 Views)
