prevent relay flicker using ni-6501
How can I stop flicker on my relays which I am driving using an NI  USB-6501. I have found several example timed VIs but they all produce a flicker.
(2,566 Views)
You'll have to give more information.  What VI are you using?  How are your relays wired up?
A flicker problem sounds like a hardware issue.  I doubt that you are going to be able to solve that with in a VI which is software.
(2,563 Views)
By "flicker" are you referring to relay bounce? If so, software will definitely not fix this, as that's a side-effect of mechanical relays. You could use solid state relays as an alternative.
Assuming, of course, you're actually talking about bounce, of course.
(2,555 Views)
