print front panel without header
Hi all... i'm using labVIEW 7.1
i tried to print a page of front panel but when the page out i found there got my file path, date time, and even my VI icon...
I had tried using "Easy Print VI Panel or Documentation " and "Print Panel To Printer Method" but the result still same...
So, got any method to avoid this problem?
with regard
Jaxx
(2,724 Views)
Go to "File...VI properties...Print Option" and uncheck the first option. See if this helps. 🙂
(2,723 Views)
i tried that before... but anyway the problem alreadt solved thanks!
best regard
Jaxx
(2,709 Views)
