print labview imaq image without border
Strange problem. I checked my system. I am using LV 7.1, IMAQ VIsion 7.1 for LV and NI-IMAQ 3.0. I uninstalled IMAQ Vision and NI-IMAQ. After that installed Imaq Vision 7.0 which automaticaly installed version 2.6 of the NI-IMAQ driver. With this setup I still have the property Image Area Size (take a look at the attached picture). The VI still works as expacted. Could you try to upgrade the NI-IMAQ driver to the latest version. You can do that at the following link:
Update Driver
Download version 3.0.1 under header Driver and install this one.
Hope this helps.
Best Regards,
RikP
Application Engineering
Rik Prins, CLA, CLED
Software Development Engineer
Message 11 of 14
(877 Views)
I was thinking the same thing, so I have just upgraded to imaq 3.0.1, but unfortuately it still does not work.
Here is what my property node looks like (see attachment).
Maybe the image area size is a feature of vision 7.1 and is not present in 7.0?
I'll update to 7.0.1 and labview 7.1.1, maybe that will help.
Message 12 of 14
(875 Views)
I've updated everything to the newest version, but still no luck.
I guess "image area size" is a property which has become available in vision 7.1.
I'll put that on my christmas list 😉 maybe the boss will be generous.
Thanks for your help.
Message 13 of 14
(865 Views)
I've now got Vision 7.1 and it works just like you showed.
Thanks alot.
Arend
Message 14 of 14
(838 Views)
