print one worksheet of an Excel workbook
I can open a reference to an MS Excel file (workbook), open a particular worksheet, and populate cells. A macro does some magic and populates cells in another sheet. What I need to do now is print a particular worksheet. Is there an example around for printing a single worksheet of a workbook. Guess I can copy that sheet into a temporary report, print the report, and then delete it - is there a better way?
I am attaching the code that I am using to open and modify the workbook - probably besides the point but will illustrate the approach I am using
thanx
lmd2
Lawrence M. David Jr.
Certified LabVIEW Architect
cell: 516.819.9711
http://www.aleconsultants.com
larry@aleconsultants.com
(2,928 Views)
Accepted by topic author lmd2
If you have access to the report generation toolkit you can use the following example Write to a Sheet other than Sheet1 of an Excel Spreadsheet (Report Gen) to print a specific worksheet.  Simply add a print report after the excel get worksheet and you should be all set.
Are you trying to make this without using the report generation toolkit?
Scott A
SSP Product Manager
(2,910 Views)
I have the toolkit on some machines, sometimes I feel more in control using low level active-X but I can go either way long as it works - thanx
lmd2
cell: 516.819.9711
(2,906 Views)
