print report in the center of paper
Hello, I am using the Labview 8.2.1. and I am trying to print a "Standard Report" which contains only a JPEG image, in the center of the paper, but it is always printed at the left side of the paper A4.
How can I choose its orientation ? I also choosed the "Right Alignement" but is printed again on the left.
Here is my block diagram.
22014i305B577724BAB0B1
Thank you in advance.
(2,630 Views)
Accepted by topic author nikosfs
Try messing with "Set Report Margins" in the "report layout" sub-vi's.  My reading of the help for "append image" to report for LabVIEW 8.2 indicates that the orientation is ignored outside of a word document.
Good Luck.
(2,619 Views)
Thank you. The "Set Report Margins" in "Report Layout" must be used indeed.
Here is the block diagram:
22062iB23B9D7600FCB4E9
(2,601 Views)
