print with continuous-feed paper
I'm using LabVIEW "print report.vi" to print out datas with continuous forms paper(連続紙).The printer is NEC PC-PR101/63, a dot inpact printer. I want make all datas printed in one page no matter how much datas are.
However printer is always push out the same size paper now.If datas' size is small,there will be a large area of blank space in the end of paper; but If datas' size is big, the datas will be seperated to N parts. I just want to make the printer to push out in a suitable positon.
Is there any method to solve this problem?Thank you.
(2,813 Views)
You can use REPORT LAYOUT VIs to set ur page breaks & margin prior to printing.  This will take no. of iterations to try out for diffrerent data sizes but it should work for u.
(2,787 Views)
Thank you for your reply.
It seems that the printer is still pushing out same size paper in this way.
Do you have some samples VI?
(2,758 Views)
I don't think your question has anything to do with LabVIEW.  It is all about how you can configure the printer within Windows to work as a continuous feed printer.
(2,748 Views)
