printing array with decimals to text file
I have tried to find this information on forums but I cant seem to find exactly what I am looking for. I have VI that when it is finished has a 2 column and 5 or so row array that is populated with heat loads and corresponding voltages. I want to print this array to a text file but I want to include the decimal places in at least the voltage. I have attached what I have, thanks in advance
(2,620 Views)
Accepted by topic author lvuser333
The answer is on your pc. If you have the context help open, click on the detailed help. There is a link there on format specifiers. You are using %d which tells the function to convert to integers. You want %f for floating point numbers.
(2,615 Views)
Change your format specifier to a %f on the Array to Spreadsheet String. I you want to have some values as integers and some as floating point you will need to use a for loop to format each row yourself using the Format To String VI.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,612 Views)
