printing bar code using HP printer
I want to print a barcode using my HP deskjet 2540 series. I have installed code128 and fre3to9x fonts in the C:/windows/fonts folder. I am using windows 7 and labview 2009. I am attaching my code. Please help
Message 1 of 9
(5,400 Views)
Hey,
could you please specify your problem, it would make things much easier to find an answer?
As things are now, I guess the answer is 42. 🙂
Message 2 of 9
(5,388 Views)
As per the "detailed help" provided in labview, I selected the font code128 so that it can convert the text string in to bar code for print. But all it does it it prints the original text. For example, If I enter ABCD instead of converting it to corresponding bar code, it prints ABCD.
Message 3 of 9
(5,369 Views)
Hey,
check out this link.
As dbriggs wrote  in the comments: "
Make sure the names of the fonts match. If an undefined font is selected then it prints the system(?) default. View the font list via the  'Install Font ...' link provided above.  I had to modify the Font Name from - 'Free 3 of 9' to 'Free 3 of 9 Regular' or 'Free 3 of 9 Extended Regular' in order to obtain proper printing"
CMW...
Message 4 of 9
(5,359 Views)
Hey, I tried the things you said, but doesnt work. fonts are correctly installed, I can see them in Microsoft word and print them also.
Message 5 of 9
(5,343 Views)
Try increasing the size of your string indicator for the barcode.
I have seen strange behaviour where a barcode wont display at all or properly until the indicator (in LabVIEW) or cell (in Excel) in above a certain size.
-AK2DM
Message 6 of 9
(5,331 Views)
doesn't work.. i tried
Message 7 of 9
(5,314 Views)
How about the example from the community I linked before. Does it work?
CMW
Message 8 of 9
(5,291 Views)
yeah that works.. but I don't understand why the vi I made doesn't work?
Message 9 of 9
(5,254 Views)
