printing easylabel formats
HI,
Im trying to print a label that was created on the easylabel software via labview, but not sure how to do this.
I was trying to use the windows API for labview to print, it works with many extension files such as .txt, .doc, etc etc
but it does not recognize the easylabel extension '.fmt' for labels.
any help on this?
i want to print it after a test is passed.
thanks !!
(5,496 Views)
Hi
I have the same problem, i didn't find any labview code example for this, only visual basic examples.
(5,245 Views)
In fact the solution was visual,
The .dll that easy label provides is only for VB, I tried to use it under labview but it didnt recognize all of the functions.
What i did was a very simple program in VB, made a .exe and with that I used LV to call that .exe and print with no problem.
(5,226 Views)
We use LabView to generate a .txt file, which EasyLabel monitors (it watches for a change in time stamp for the trigger)
You have to launch EasyLabel in CMD file monitor mode, and the CMD file includes the path for the .txt file
(3,996 Views)
Hello do you have the sample code to share with us?.
Best Regards
(1,633 Views)
I doubt BenchGuy is gonna answer ...
Qestit Systems
Certified-LabVIEW-Developer
(1,615 Views)
