printing in LabVIEW
If i have a picture box on fron panel whose size is larger then the screen width then waht to do?How can i get the whole picture in landscape paper?
(2,714 Views)
> landscape paper?
Are you printing the VI panel or using a capture program. Printing of a
panel doesn't normally use the window size, or at least it is an option.
If the picture itself is too wide for the printer and the window, you
might try turning on Scale to Fit. This will shrink panels up to 4x in
both directions to make larger panels fit a page.
Greg McKaskle
(2,714 Views)
