probe watch window showing shared variable in write mode not executed but same shared variable in read mode showing values.
I am using shared variable between NI PXI-real time target and host computer. When i probe (probe watch window) the write-mode shared variable at Ni-PXI, it is showing not executed. But when i probe the read-mode shared variable at host computer, it is showing values that are shared.
Shared variable properities
data type- array of double
variable type- network published
RT FIFO- enabled
FIFO type- single elements, number of array-1, number of elements-3
Could you please someone tell me, why so this is happening?
Thanks in advance
(3,185 Views)
RT FIFO- enabled
Could you please tell me, why so this is happening?
(3,152 Views)
Take a look at the following link if you haven't already:
http://digital.ni.com/public.nsf/allkb/6E37AC5435E44F9F862570D2005FEF25
This article goes over several Network Shared Variables troubleshooting steps and may contain the answer you are looking for.
Alex C.
Alex C.
Applications Engineering
(3,112 Views)
