probe window: how to turn "do not ask" off?
When I dismiss the probe watch window, there is (by default) a "Are you sure?" dialog. There is also a "do not ask again" checkbox. I checked this box a while ago, but now would like to be asked again. I cwould like to find out how to un-do this choice, and turn the dialog back on.
Thanks!
(2,940 Views)
Open your LabVIEW.ini file, and fine the line:
WatchWindowDoNotAskOnClose=True
And remove the line and save, or change it to a False.  There might be a menu somewhere to re-enable it but this is where it is stored.  You may need to restart LabVIEW.
(2,925 Views)
Thanks very much!
-Jeff
(2,915 Views)
@JWP@sal.wisc.edu wrote:
Thanks very much!
Thanks are given with kudos, and marking solutions in posts.
(2,908 Views)
