problem -10401(LabView-calibration)
I have the PCI-MIO-16E-4 DAQ with
CB-68LP. My problem is that I can't calibrate the card because error -10401
appear. The first person that will tell me the correct answer I promise that
I sent him a high T bismuth superconductor from Colorado superconductors
Inc. with thermocouples.
Thank you
e-mail: loukasfe@hotmail.com
(3,018 Views)
You didn't mention if you had tried anything in the way of troubleshooting, or
checked the NI KnowledgeBase. A quick search suggests that perhaps you need to
wire the device number of your E Series DAQ device into the task ID input,
assuming you're using the Calibrate VI all by its lonesome.
This advice probably isn't worth the superconductor, but I appreciate the
incentive!
John Lum
(3,017 Views)
