problem about Using DataSocket when the URL points to a file
Hi
I try to start a application example named DS Writer.vi and DS Reader.vi
which is located in c:labview\examples\Comm\datasktx.llb for learning
DataSocket on LabVIEW5.1 .
I read the vi information of the examples named DS Writer.vi and DS
Reader.vi , they tell me that the VIs can work writing and reading the
wavedata to and from local files. According prompt in the panel of VIs,
I give same URL( file:c:/chj/newwave.dsd ) for DS writer and DS Reader, then
start the VIs. I can see the waveform (living data) in panel of the Writer,
but nothing in panel of the Reader. And I can find out the file
(c:\chj\newwave.dsd), 1KB size, DataSocket Data type. The both status
indicators give information (
Idle: Data written. Idle: Data read.). So I
wonder what's matter, and why I can't see the waveform in panel of Reader.
Maybe I should do something for DataSocket.
Using dstp://localhost/newwave point to the URL for Writer and Reader, it's
normal. And when I set the URL
file:c:/labview/examples/comm/dsdata/tone.dsd which have been existed in
local machine) into the penal of Reader VI, I only start the DS Reader.vi ,
I can see the waveform. so I think the above file
(c:/chj/newwave.dsd ) written by DS Writer is bad.
Who know why? I enjoy understanding that. Thanks.
(2,831 Views)
It could be that you URL format for file is wrong, normally it is like this
file:///C:/WINNT .
Reinis Kanders
"Cheng Huijun" wrote in message
news:394dd9e7@newsgroups.ni.com...
> Hi
then
Writer,
> but
> indicators give information (Idle: Data written. Idle: Data read.). So I
it's
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 80,000 Newsgroups - 16 Different Servers! =-----
(2,831 Views)
