problem about application builder
I've created the software which has main software that will call several small
vi to do difference task by using vi server. The software has worked nicely
in programming environment.
Then I used application builder to create a executable file. When I called
it the main software opened correctly but when I tried to call other small
vi, nothing was happened, no panel display. I also tried to use another option
that creat small application with external files for sub vi. but it didn't
work too.
Anyone coule give me the suggestion how to solve this problem I would be
very appreciate. Thank you so much in advance.
(2,808 Views)
hi,
you should add server VIs as Dynamic VIs in the 'source files' tab.
this solves the problem.
ozan...
"svp" wrote in message
news:3a235bb0@newsgroups.ni.com...
small
nicely
small
option
> work too.
> ve
(2,808 Views)
