07-22-2008 02:15 PM
07-22-2008 02:28 PM
07-22-2008 03:45 PM
07-22-2008
03:57 PM
- last edited on
10-27-2026
12:34 PM
by
Content Cleaner
I wrote a couple of examples showing 2 different ways of doing this. You can find them in this thread. The first example uses a dropdown to select the plot. The second example lets you click on the plot. This second example is at the end of thread.
Message Edited by smercurio_fc on 07-22-2008 03:58 PM
07-22-2008 03:59 PM
07-25-2008 05:23 PM
Hi smercurio_fc:
Thanks so much, that what I want to impement!! I really appreciate your help.
But I still have some questions about it.
1. can I zoom in and out in that "waveform graph"??
2. can I display the plot array or plot index that I select in the waveform graph?
3. I build a sample codes for my project, in which , I used a random number generater to simulate a DAQmx data collection, and generate a overlapping waveform in the waveform graph.
but it seems the program is not stable, when i first run the codes, it is ok, and I can select the plot what I want. but after I stop and restart the program, there is error message about "Property Node".
it seems something wrong about the "waveform graph properties"
I attached my codes here, anybody know what wrong about it?
thanks a lot
07-26-2008
03:10 PM
- last edited on
10-27-2026
12:34 PM
by
Content Cleaner
You can do this using the graph palette. Just make it visible. The middle control allows you to zoom.
You can connect the same wire that goes to the ActivePlot property node to an indicator.
3. I build a sample codes for my project, in which , I used a random number generater to simulate a DAQmx data collection, and generate a overlapping waveform in the waveform graph.but it seems the program is not stable, when i first run the codes, it is ok, and I can select the plot what I want. but after I stop and restart the program, there is error message about "Property Node".
For some strange reason the property node is "messed up". I've seen this happen sometimes with graphs. I don't know what causes it, and the only way I've found to fix the problem is to delete the graph, put a new one on the front panel, and recreate the property nodes. I've typically seen this happen when copying code from another VI that has a graph with property nodes, as I suspect you did. If you delete the graph, put a new one on there, and recreate the property node you should be OK.
That said, a few comments regarding the code:
07-28-2008 11:20 AM
Hi smercurio_fc:
Thansk a lot, I really appreciate your help.
I think the problem which casue the "messed up" of property node should be something about "race condition" problem.
But I am sorry , I don't really understand what is race condition problem and why there is such a problem in my sample codes?
Thanks for your suggestion, this is very important for a Labview beginner.
regards
07-28-2008 01:12 PM
07-28-2008 02:19 PM
