problem applying clean up diagram
Applying Clean up diagram, so that it ordered the scheme, some letters of variables in "Formula Node" are outside the box (some completely), but does not affect operation, anyone know how to fix it and did not write the variable back? . Attached image of a "Formula Node" where the problem arises.
(2,711 Views)
Accepted by topic author cobalto
I would try moving the terminals back to the side of the node instead of being on the bottom.
(2,695 Views)
