problem changing VISA synchronous state
This seems to be a bug.  Can I get a CAR number for this?
http://forums.ni.com/t5/LabVIEW/Changing-VISA-Synchronous-state/m-p/2358338#M735511
Trying to change VISA read/write synchronous state.
LabVIEW Help says to right click on the node and select the mode you want (Synchronous I/O Mode).
I right click on it, See that "Synchronous" is checked, and because it is easier or built into my mouse memory I just re-assert the click on and choose "Synchronous", except that when I do that, it changes it to Asynchronous.  It behaves as if any choosing of the Synchronous I/O Mode just toggles the state, instead of actually setting the state to what you chose.
This does not seem logical to me.  Am I doing this right, or is there some other problem going on here?
(2,426 Views)
Hi Warren,
I looked at the issue you have described and filed a CAR. The CAR number is 399613.
Arham H
(2,388 Views)
