problem chart
my problem is that i want a chart with 8 lines.
if i build an array with 8 values the chart draws it like one linie with 8 values and not like 8 lines with one value.
i've tried to build this array in a while loop with shift registers.
there was the next problem. my chart shows me 8 lines, but every cycle it shows me the hole array again.and doesn't delete the old values.
so it can be that the chart shows me the array ten times.
(2,653 Views)
Hi Weber
I guess you want 8 horizontal lines.
Ok. see attached doc.
Hope it helps you
Alipio
"Qod natura non dat, Salmantica non praestat"
(2,653 Views)
