problem compiling a fpga program on windows 10
I'll start by saying I have not used LabVIEW in a professional setting. I've only taken a class on LabVIEW and have other programing background. I'm using a cRIO to control a NI 9505 for motor control for my new job. The Problem is when ever I try to compile it gets stuck in a random step of the process and never finishes. I think this is because I am using Windows 10.
I've let It run for over 15 hours and still I am not able to compile. No errors show up in the logs, it just gets stuck in the process(I've uploaded a picture of what happens when it get stuck). I don't have access to a local machine on my network with windows 7 nor do I have a cloud compile service active.
Does anyone know how to fix this? Is it even possible to compile on windows 10?
(4,069 Views)
Do you happen to know where I could find information to get my cloud compiler working? I currently have the 60 day cloud compiler trial active on my account, but I get this error(picture attached). I think my IT is blocking something. I just don't know what.
(4,045 Views)
Here: https://users.niwsc.com/compilecloud/#/
If you have an active SSP, you have it already.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(4,043 Views)
Accepted by topic author truby
I was able to compile on windows 10 by running LabVIEW, as well as, the compile worker in windows 7 compatibility mode. Hope this helps others.
(3,989 Views)
