problem for building xls file
Dear all,
                   I am beginner for LV,could you help me?Why are they different between a.xls and b.xls which they were built in the enclosed vi file?
(3,093 Views)
Your question does not seem to convey what really is your problem.
You are having two 2D string arrays which you are writing into two individual files.
On running ur vi, It also seems to write data in two seperate files.
So, can you be more explicit about your doubt?
regards
(3,085 Views)
Dear Devchander,
       Thank you for paying attention,I have had a solution to this problem.
In fact,This problem is really that the array format of building xls file was different with
two arrays of string.these array of string are seem same,but a string element of the array
contained end-of-line vulae for one,and a string element of the array no contained end-of-line
for another one.
        By the way,my English is not well done,could you understand above sentence for my mean ?
(3,075 Views)
HI,
Try selecting 'Pos mode' in 'file write' as 'current'.
This might help
Regards
Dev
(3,072 Views)
