problem in acquiring multiple analogue signals
Thanks for replying. I highlighted what i tried but does not work it keeps looking for click. Can you explain me in detail. If i put build array how will that work i tried but does not seem to be successful, may be wiring wrong wire.
Message 11 of 17
(730 Views)
Take a look at the example I wrote.  I think this should demonstrate how to accomplish what you are trying to.
Greg H.
Message 12 of 17
(720 Views)
Sorry, still not clear. I know you are comparing delay time to start graph with elapse time and when it is true allowing to build array inside case structure and if it is false do nothing. In my case it is ok button. Problem I am facing is when i release it it does not plot so i need to keep clicking when i need to plot it. Is there any function which automatically clear graph or array when it is called. So i can run the graph and use logic when initial reference is clicked erase and plot again.
Please guide me through this.
Himanshu
Message 13 of 17
(715 Views)
Try the attached example.
Greg H.
Message 14 of 17
(707 Views)
Thanks, is it possible you can attach in 8.6 version
Thank You
Himanshu
Message 15 of 17
(702 Views)
I thought it was, try this one.
Greg H
Message 16 of 17
(699 Views)
Thanks Greg
Message 17 of 17
(685 Views)
