problem in converting a simulink model in LabVIEW 2010
hello,
I have developed a Simulink model in MATLAB which I want to convert into equivalent LabVIEW VI's. The simulink model is as attached. The problem here is:-
LabVIEW is not able to convert all the mechanical blocks named Ankle revolute joint, Body , joint actuator and joint sensor into  equivalent LabVIEW VI.
Is it possible to convert those blocks into equivalent LabVIEW VI's?
PS:- I am using LabVIEW 2010.
Message 1 of 1
(2,353 Views)
