problem in placing controls and indicator on imported pictures
hi.
i have a problem in placing controls and indicator on imported pictures on labview front pannel.
when i place a control or indicator on imported picture ..the control or indicator don't stay at the top of picture but go behind the picture...
kindly tell me what to do to avoid this....as complete project has been made and now i have to place all controls and indicator of front pannel on to a picture.
(2,601 Views)
The Front Panel is built in layers. Each new control or decoration you add is placed in the top most layer.
To change this, select the picture, click the "Reorder" button (that's the rightmost button in the row of buttons on the toolbar, the one with the 2 arrows forming a circle), and select Move to Back. Your picture will be moved to the background and your controls will be in front of it.
___________________
Try to take over the world!
(2,599 Views)
Hi
don't forget to group and lock picture plus controls after you are satisfied with set up.
Saves having to rearrange every thing later. ( especially if you transfer to larger monitor)
chow
xseadog
(2,587 Views)
