problem in saving data in spreadsheet that comes from DAQ
Hi
I am new for using the Labview. I have problem saving the data in spreadsheet. mine just save the last reading that come from DAQ. And can not figure it out .
If  there is way to make it save all the data with the time when I start run it till I stop it,please
Thanks in advince
Message 1 of 10
(3,545 Views)
The data coming from the while loop in the second frame of the sequence structure is only the data from the last iteration.  This its the way dataflow works. If you have not done so, work through the on-line tutorials to learn more about LV.
To get all the data you can enable indexing to create 2-dimensional arrays.  Queues or functional globals (or Action Engines) can be used to get data from a loop before it has finished executing, but that would not help with your architecture.
Stacked sequence structures are almost never the best choice for a program.  I have not used them since about 1991. Learn about state machines. They are more flexible, powerful, extendable, and maintainable.
Lynn
Message 2 of 10
(3,538 Views)
try the attached VI..it should write all the data............ It is not the best way to use stacked sequence structure...........
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
Message 3 of 10
(3,528 Views)
I've changed the architecture to something that is way better then the sequence structure you had (State Machine).  Just to give you an idea on how it could be done.
Still the dynamic data type is in there (which I don't like), but I'm not going to change your method.
I've cleaned up your code a bit.  It's still not perfect, but it's done in 2mins.
I do have one question though : why are you saving an entire column (the last) of data which contains the same value (namely the total time the test ran)???
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
Message 4 of 10
(3,521 Views)
Thanks Lynn , Smiley Happy
Message 5 of 10
(3,503 Views)
Anil thanks alot for the help , but i could not open it coz i have LabView 8.2
if you can attache it again with 8.2 8.2 version pleaseSmiley Happy
Message 6 of 10
(3,499 Views)
Thanks alot Bjorn  , I would like to see the architecture ,but the labview that I am using is 8.2, If you can reattache it please
regarding the question,:
smileysad: I do not need that column ,and I do not really know why is that .
I tryed some string ,but I was not lucky for the right one  Smiley Sad
Regards
Message 7 of 10
(3,488 Views)
Hi othman,
Downgraded it to 82.  If there is something you don't understand, don't hesitate to ask
Kind regards,
- Bjorn -
Message 8 of 10
(3,478 Views)
Dear Bjorn
I am trying to see the effects of  DAQ assistant properties on the
reading. like changing sampling rate , different frequency deferent
mode.
when  I increase the sample to read the time increase . and the time is not any more is the  actual time of reading
my questions
1-what would be  the recommended mode for thermocouple
2-If i want the correct time for the reading
3- the saved data start with different time in the  previous program .  to make it start from zero just when i press continue button ,
I have a LABVIEW 8.2 and NI USB-9211A
I hope to have your kind response!!
Thanks alot
Message 9 of 10
(3,442 Views)
in 8.2
Anil Punnam
CLD
Message 10 of 10
(3,436 Views)
