problem initializing shift register
If you want to average over mutiple calls of this FOR loop, use e.g. the "First call?" primitive for the case structure.
Message 11 of 16
(1,572 Views)
I did exactly what you did, and the graph gave me the same waveform I sent in.... and then I made the case that sums two iterations as case 1 and wired constant 1 into the case selector terminal. With that when i highlight the execution, i see that my values are being summed up, but the problem is that the graph doesnot show anything at all. when I wire 0 into case selctor instead and highlight execution I see that my waveform is being send directly without any change and the graph also shows me the same waveform that I send in. i do not understand what is going on! =(
Message 12 of 16
(1,569 Views)
ATTACH your code!!! 😄
That's not what I did. In my case, the selector is connected to "[i]+1" and the sum takes place in the "0, default" case.
Message 13 of 16
(1,549 Views)
bump! can anyone please help!
Message 14 of 16
(1,548 Views)
Ya I did what you showed and I recevied the same wavefrm that I sent in... that's why I tried making it case 1 and wiring 1 into the selector terminal. just a sec I'll attach the program. thank-you very much for your help!
Message 15 of 16
(1,546 Views)
Hey Altenbach thank-you so much! It worked. Apparently my case was not wired correctly!
Message 16 of 16
(1,542 Views)
