problem measuring with Omron ZS-Ldc in labview
I have sensor ZS LD50 and controller module ZSLDC. Which gives a output signal ranging more than +- 10v
I want to know is that safe to connect to the connector board CB-68LP and NI PCIe 6343. Will this volt can be handled by the NI unit.
If I connect signal source terminal with two series resistance to divide voltage, I am getting lots of buffer, from which I couldn't measure accurate displacement .
Kindly evaluate the program I made for displacement. &  How to tell  "save to measurement file" get reading in mentioned timing.  i.e.:  save 10 data in one sec
I am basic learner, so kindly correct me i am wrong.Thank you
(2,416 Views)
Hi Ashwin,
The CB-68LP manual states the safety voltages.
Taking a brief look at your code, I can suggest the following:
  • I would expect your program to "buffer," or take a long time to execute based on how you have things setup. Best practice would be to acquire data in one loop and record the data in a separate loop. I would start with an example (Help >> Find Examples >> Hardware Input/Output >> Analog Input), then work from there.
  • Post code, not screenshots. We cant see how you have things configured with just a picture
I am still not clear on exactly what you are trying to do and what issues you are running into. You may get better responses posting this in a DAQ forum rather than a LabVIEW forum.
Could you help us understand exactly what you are trying to do and exactly what errors you are running into?
Clint T.
(2,384 Views)
