problem to sort data in array
sorry im still new in Labview..can i know how do i change the mechanical action to switch?
Message 31 of 50
(2,808 Views)
To change the mechanical action of a boolean control context-click on the control and select Mechanical Action (near the bottom of the pop-up menu).  Switch when Pressed is probably the choice you want if you will be using locals.
Latch when Released is the default action for Stop and OK buttons because the switch setting returns to False when the switch is read by the program.  This makes it behave like a momentary switch.  Because of the way dataflow works, the Latch type actions cannot be used with local variables.
Lynn
Message 32 of 50
(2,804 Views)
@icycool wrote:
i've tried it but didnt work..i make a local variable from loop 1 and connect it to stop at loop 2 and vise versa but still cannot
NO! No local variable needed here! Keep it simple!  Delete the stop button in the left loop and place the remaining stop button in its place. You don't need the terminal in the event loop.
The UI loop has an event structure and and event case for a value change on the stop button, thus there is no need to have any local variable there. You have one event case shared for "clear" and "stop", thus simply invert the "clear" and wire to the loop condition. Two possible cases:
  1. "Clear" was pressed. Inverting the "clear" causes a FALSE and the loop continues
  2. "Stop" was pressed. Thus clear is FALSE and inverting it give a TRUE to the loop condition and both loop stop. One directly, one via the event structure. Makes sense?
(Alternatively, you can make a unique case for "STOP: value changed" and use either a boolean TRUE constant or the "Newval" event terminal to stop the event loop)
In summary:
  • Ignore all misguided advice about adding local variables
  • Ignore all misguided advice about changing the mechanical action of the boolean.
Both simply complicate the code for no real benefit. 😄
Attached is a quick rewrite (LV 9.0).
Message 33 of 50
(2,797 Views)
oh i get it now..thanks a lot!
Message 34 of 50
(2,793 Views)
hi,
i need some help to change my vi (attached)
as u can see my current program looks like this - if 2byte receive is 1111 then the value after it will goes to 1111 column then if 2222 then it goes to 2222 column but i want to change it to be like this - i'll receive one frame containing 7bytes continuously, so then i want my program to make byte2 go to column 1111,byte4 to column 2222,byte6 to column 3333 and byte7 to column 4444...im only need 4 data here..the received byte is in hex but i want it in decimal as it is put into the table
Message 35 of 50
(2,739 Views)
sorry for the trouble before
the problem is the received data i got is not like what i expecting before..so i need to make some change to this vi
now i received continuous frame..each frame contain 7byte which is 7 different data..but im only want 4 data from this 7 which is byte2,byte4,byte6 and byte7..and i want it to be put into my table in decimal value
Message 36 of 50
(2,732 Views)
That seems like a trivial modification. What have you tried so far?
Message 37 of 50
(2,718 Views)
yeah that maybe trivial for u but its hard for newbie like me..i try delete the ordered tags part and its connection but still cannot
Message 38 of 50
(2,703 Views)
attached is how the 7byte data received will looks like..and the manual for the data
so here i want my program to get the value of input voltage,input current,output voltage and temperature into the table each time i received it
really need ur help for this one
Message 39 of 50
(2,698 Views)
Renaming a bmp to jpg to get around the ban on posting bit maps is NOT appropriate.
Message 40 of 50
(2,653 Views)
