problem using DPO7254 IVI driver
I have coded up a routine to setup a capture, aquire the waveform and then use fetchwaveform to get the ata and display it on the computer.  This works great with my TDS5054, but now I am trying to get it to work with my DPO7254 and the fetchwaveform times out with an invalid parameter error.  I have checked the handle and channel name.  Same ones all the previous calls used and worked fine.  I see the scope getting configured and setup.  Then it triggers and captures the waveform on its display.  But the fetchwaveform just fails.  Anythoughts?
(3,316 Views)
The error message is "Primary Error: Invalid value for parameter or property"
(3,303 Views)
I have determined it is the virtual channel name.  The fetchwaveform call seems to be very unstable.  Sometimes it works and sometimes it doesn't.  I have not been able to figure out what is causing it to lose track of the virtual channel mappings.  Any ideas?
(3,286 Views)
Hi Muffin,
Are you using this driver in LabVIEW or a text-based environment?  Also, what are the inputs to the fetchwaveform call?
I am not familiar with this driver, but it might be that this call takes slightly different options depending on which scope it is used with.
-Jim B
Applications Engineer, National Instruments
CLD, CTD
(3,257 Views)
I am using it in Labview 2013.  It is in the IVIscope subset so it is not scope specific; that would kind of nullify the point.  It is a fairly simple VI as it only takes the handle, channel name and error in.  It is in the low-level section, but so is the initial acquisition which I use prior to it and that works just fine.
(3,246 Views)
